AC Delco EGR Part Numbers
jeff in co
Colorado Springs
So, the original AC Delco EGR valve that I pulled off was: 17087194
I believe it was change or updated to part #:19210654
Both of these line up to 214-5073
So, I order it up from Advance Auto.....box arrives with the 214-5073 part number on it, as well as 19210654.
But when I pull the part out, it says:
19209958
120421
I've tried to look these number up but found nothing. :dunno: Is this some new number or is the wrong part in the box?
Not you? http://www.fullsizechevy.com/forum/...irculation-troubleshooting-3.html#post5772926
The fact that the Delco site interchange doesn't cross the 9958 number, and your post and the one above are the only ones found via google, leads me to believe thats not a part number. If it was an old part number or something, should still see results in google IMO. Might be the part number for that portion of the EGR? Dunno.
No not me.....but that was the only reference I found too. Just seemed odd.
Well, out of curiosity and also price, I purchased the same part number from Amazon and waited for delivery (214-5073). Sure enough, they are in fact identical so I guess the number on the valve is a manufacturing type number. Both were, unfortunately, made in China now.
Part numbers changed, updated etc but still gets tossed in new box. Plus pretty sure Airtek Wells is the only one making them these days in a few different factories. AC box, BWP box, NAPA box...same Chinese part.
Theoretically that is the right part but quality wise... not so much.
Original GM# was 17111851 which is a 17087194 and will cross to several others.
This is what I put on mine.
And to avoid China syndrome buy a new old stock off ebay. Ask seller if made in US and go forth! Loads of them out there for like $20-$30
