You can't live without AC in the south....15 seconds and your "drawers" are drenched...and your socks...and your shoes are filling up with sweat...
what year ranger??? The mid 90s up stuff is notorious for blend door issues. From stripped out blend door motor gears to actual broken blend doors. It happens to all of them.
OK, newer than I thought. Almost certainly electric, so forget all the vacuum stuff.
I understand why everybody has gone electric, but they just don't seem to hold up like the vacs.
Not sure where the blend door is on that model, but if you can get to it, and get it in the right position and just disconnect the wires, you will stay frosty until winter.
check the lines going to and from...they crack & leak over time...![]()
OK, the vacuum ball is a reservoir, like a water tank. The system will work without it.
Its only needed when you romp on the throttle and the vacuum goes away for a few seconds.
You can bypass it to see if it fixes the problem.
If it has two lines, just hook them together.
I had one go bad in 1971 T-bird. When you stomped on the gas on a hot day, it would go from full cool to full heat.
Not fun.
