First time using this type of gauge set. Have always wanted to get a decent set but nothing justified getting a set until now with the 91 Blazer's aftermarket Frostemp AC made by Wynns back in the 90s. After pulling a good vacuum an hour, I loaded three 12oz cans but left the last can with a little left so maybe 28-30oz total. The Vintage AC systems are known to take 28 oz and it appears mine is similar in size. It was 70 degrees outside so it looks like I'm good going off this chart. The system is blowing cold but don't have a temp gauge to measure temp. With the AC compressor cycling, do these gauges look to be in normal ranges? I'm pretty stoked to get this AC up and running after sitting for over 15 years and the system was missing hoses, missing condenser, and had a bad compressor.
