Last year the AC in my wife's van ('01 Caravan) died. Sounded like a compressor, so we had the dealership replace it under the extended warranty.
A week ago it did the same thing. Warranty was up and I can't even see the durn compressor so we took it to a local shop. They said it was the AC clutch. They replaced it - AC worked for a day and then quit again.
Took it back and they said it was way overcharged (they hadn't checked it before). They took out 4lbs and put back ~2lbs (dealership overcharged last year?). AC worked OK for a bit, now it is pretty marginal.
I put my gages on it today - it still read high and didn't cycle on and off like I expected. Pressure was 60psi low side and just over 100 high side. I let some out until it went to about 40psi low side 150 high side (took to much out?). It got perhaps a little better. Still not as good as it was a week ago and still not cycling.
Any ideas? Bad pressure switch?
BTW, don't vent R-134 near the airbox.
