jteck10
sorry if this is posted in the wrong spot.
I recently had my belt rip apart on me in my 1990 k5 Blazer
when i went to put a new one in, i noticed the connector on top of the AC compressor was about to fall off
(before the belt ripped, my AC and heater both worked fine)
so as i pull the connector off to clean and put back on, the two tabs on the AC compressor completely break off
i took the truck to a shop and had them depressurize/repressurize the system, i replaced the AC compressor and put the connector back on the new compressor
now when i try to turn on my air, i get a faint hissing noise from each setting (defrost, etc.) that slowly fades as i change them
no AC, no heater
the shop told me i had 1.1lbs in the system, and they replaced 1.1 lbs
im going to start with fuses, but anything else that might be preventing my heater/AC from working now?
vacuum leak somewhere? blower motor for the heater out?
any help is appreciated
no AC, no heater
