bigred88
My heater core is leaking, my blend door tab is broken, my vents either face the floor or face the ceiling and are liable to change from one position to the other with each bump, and I pretty much only notice flow out of the vents with the blower on high because there are so many leaks along the way. And this is my dd- all in all it works well enough, but I'd like for it to be right. So the plan is:
New heater core
New blend door tab thingy
Stiffen the vents if possible/new vents if not
New gaskets/foam/tape all junctions
The heater core and blend door tab I've got covered.
As far as the vents go- does anyone know a way to keep them from just swinging down and facing the floor, or do I need to just buy new ones? I don't really care about the bright and shiny look of new ones (I think the new look would clash with the style I've got going on with the rest of the truck
), I just want them to stay where I have them aimed at. Has anyone bought new ones? Who did you buy from, were you satisfied, etc?
And the gaskets/foam/seals/whatever you call them- does anyone know of a kit out there that would cover all of the under dash AC ducts? LMC sells them piecemeal, Cheyenne Pickup has kits, but only for up to a 72- not going to work for me. I'm not aware of any other vendors for this stuff- I'm sure they're out there, I'd be glad to hear your recommendations.
And I was thinking I'd tape over all the seals as a second barrier, but I have no clue what tape to use. Is there a specifc type of tape out there for this (and to the first smart ass that says duct tape...
)? I'm looking for something that isn't going to dry up too quickly, and also that will not allow air to pass through.
Thanks!
New heater core
), I just want them to stay where I have them aimed at. Has anyone bought new ones? Who did you buy from, were you satisfied, etc?And the gaskets/foam/seals/whatever you call them- does anyone know of a kit out there that would cover all of the under dash AC ducts? LMC sells them piecemeal, Cheyenne Pickup has kits, but only for up to a 72- not going to work for me. I'm not aware of any other vendors for this stuff- I'm sure they're out there, I'd be glad to hear your recommendations.
)? I'm looking for something that isn't going to dry up too quickly, and also that will not allow air to pass through.Thanks!
