I have a 1984 k5 blazer with the 6.2 diesel and I am trying to get the ac working on it. My wife has lupus and cannot ride in the hot weather without any ac so I took it to a shop.
They changed it over to r134a, and tested it. It holds a charge and doesn't leak however it only works on the floor mode.
They told me it was either the vacuum pump or the control unit.
He wanted 951$ for the pump, and did not tell me a price on the control unit.
I looked online and i can find the pump for about 150-200 ish. If it is the pump has anyone switched them and was it hard or did you need an ac machine to drain and refill it?
As far as the control unit is that just the little switches that move the positions, and is that an easy swap?
thanks guys.
thanks guys.
