Jumpering the pressure switch will divide the problem for you. No compressor = electrical problem. Compressor but no cooling = charge problem (i.e. leak). However, it is possible to have both problems.
FYI, the low side pressure switches go bad on a regular basis. The contact resistance gets too high to engage the clutch. However, they generally can still pull a relay, so you can add a relay to fix this problem. Then your maintenance is just new relays ($3?) instead of new pressure switches and the current is so low that you stop ruining the pressure switch contacts. And BTW, the pressure switches are adjustable. You want to tweak the setting a little when you switch from R-12 to R-134 and it brings the vent temps down a bit.
If you want to go much further, you will need a gauge set, but I have done jobs before with nothing more than a can tap and a single gauge (for the high side) after paying a shop $15 to vacuum the system down. With CK5 and a modest tool investment you can do this yourself for less money than one trip to the shop.
