all new ac components, compressor, condenser, evaporator etc. I put 3lbs R134 in the system and I can only seem to get the duck vents to blow at about 50. The compressor is cycling on and off consistently. It seem that the low side cycles from 30 to 50ish psi. It acts if its low on Freon but like I said I have 3lbs in it. should the compressor be cycling or should it be staying on the entire time? Any thoughts or ideas?
The weather in Michigan is 40 degrees and rainy right now. Not the ideal time to be tuning an AC system but components failed so I am fixing them.
thanks
thanks
