77fixer
This is a relay from AC equipped truck. It has 5 pins. The two on the ends are 10 or 12 guage, the two across the middle are 16 ga orange (switched) and 16 ga black (ground). The 5th is 16 ga blue and I'm trying to find out what it's purpose is.
On a regular relay it should have power when the relay is de-energized. It doesn't seem to work that way, or else that pin is bad.
I can't find any wiring diagram that has this relay, in either my Haynes or Chilton manual.
