The heater obviously gets warm.. The core IS in the box tho, so it's not bad at all... you could run anything an inch or 2 from it and be confident..
pulling out the whole ac/heat would give someone a ton of room right on that interior passenger firewall.. a ton of room, could mount 2 of the summit heaters...
i'll be ducting one of the 2 ducts to the defrost (just run a flexhose up to the factory Y-diverter.) and just leave the other pointing at the floor... little tighter fit in the middle but still doable...
as for heat, i'd say it puts out about 80% to 90% of what a factory unit puts out...
Do you happen to have any pics of how you set up the Mojave, or did I somehow miss it?
