3MAX
Does anyone have a diagram, or can at least walk me through how the compressor clutch should be wired up? I've searched here and other sites with no luck.
Can't confirm 100%, but I think the A/C components and operation didn't change from 85-91 in Blazers. There should be a plug with two wires that goes into the compressor, and a ground wire. there is a two-wire plug that goes into the pressure switch, which is located on the side of the accumulator. Basically, all that switch does is close the circuit if there is sufficient pressure in the system, and allow the clutch to engage.
If the ECU has any bearing on operation, I would think it would only be involved in idling up the engine when the A/C is turned on, which was accomplished by a solenoid prior to fuel injection.
These wiring diagrams may prove useful:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11766.0
I have the factory electrical manual, but no way to scan it...
Alright - I believe I've got everything wired up correctly. The compressor is operating and the system is now blowing cold air, but only for a couple of minutes. The high pressure switch is kicking the compressor off after only a couple of minutes of running, then it will cycle about every 30 seconds or so (high pressure switch continuing to cycle).
I've read that R134a runs a higher pressure than R12 (the system was just charged with R134a). The high pressure switches appear to be color coded for various pressures, but I haven't found info to tell me which one I need. Can anyone confirm what color switch should be used with R134a?
Have you hooked up a set of A/C pressure gauges? Frequent cycling of the clutch may indicate a low charge. Are you certain it's the high side switch cutting out the clutch, and not the low pressure switch?
As for the color code, I'm not sure what the difference is, although they do appear to make ones for OEM and for 134 retrofit...
http://www.autopartswarehouse.com/shop_parts/a-fs-c_switch/chevy.html
yes sir, I'll work on it tomorrow...
BTW, the switch attached to your receiver/dryer should be adjustable...
Remove the plug, there should be a screw inside that "fine tunes" the pressure controlling the cycling points for the compressor.
I did mine 2 weeks ago.
FWIW, I have a '90 'burb & manual.
