Well got all of the gear fabbed out to test the a-6 in the whell well location. I took a remanufactured western snowplow motor and fabricated an 2" 1/2" v-belt pulley, the shaft onthe motor was .855" with a facked off keyway, so I figured I'd just make my own.The set up looks good and doesn't sound loud, but the problem is that as soon as begins to fill with air pressure, the motor won't spin, it just stops in place. Worst case I found out the direction of rotations for both the motor and the A-6 compressor. Might sitll have a use for the motor, before I give up I'll try and spin the weldenator because I don't have enough room under the hood for all three. I'll give the weldenator it's shot on the motor sometime this week.
