Action shots
79k20350
3/4 ton status
Ct
Im just a little pic whore and im really excited that its running again. her are some flex pics. the front tires a little over 3ft off the ground when the back started to come up. theres just no enough weight in the back, if you push on the tire thats up it will sit on the ground. it will all come with time... there are more in my profile :D
i busted the u joint on the drivers side of the front axle so theres no four wheel drive at the moment. the tires were just spiingin out back so i needed a little help... :D its alright, ill have the 60 in it soon and should be good to go
