I know some of you have put a np205 an 4l80e utilizing the 400 adapter. I also know that SweetK30 has also built a spacer to combat the interferance with the tranny pan and to also give him a longer front drive shaft at a better angle. Not here comes the Question. When using the spacer can you use a th350 adapter? i understand that the input will still need to be changed but is it doable. the reason is that i have a th350 adapter and sont want to shell out the bucks if this can be done. also can a np205 figure 8 case be drilled and tapped to use a np241 adapter? once again i have this adapter also. any help will be greatly appreciated.
