add-a-leaf ?
Russell Keys
Huntsville, TX
I have a problem with the p-side sitting 1" lower than the d-side. Will add-a-leaves rearch both springs to the same, or will one still be lower?-Russell
I think one side will still be lower.
Check your frame, though. My front was off to one side and it wasn't the leaf pack, it was a bent framerail (eeek.)
-- Mike
Just have a fat chick drive your Blazer for a month straight! That should make all springs saggy.....
Rearching might work, or maybe its time for a lift
. My old springs sagged on one side, and I put a 1" block under them and it helped . ORD also makes some add-a-leafs that add one inch, but are for the "saggy butt" that most K5s have. Those might work if you just put it on the lower side.
90K5
Add a leafs are made to increase load carrying capicity.
When your springs start sagging add a leafs are just a tempoary fix. And from my experience they make the ride harsher.If the springs are wore out, the bushings are too. It is far better to save up your money and get new springs and bushings. Your butt will thank you for it.
