badmix
I could run a filter from Fuel Pump to Carb, but ive SS Braided lines and there isnt much room to put an inline filter up there. Is there anyway to add one to the frame rail like most modern cars. When I was under the truck this weekend, I see one of the fuel lines had a 1 inch thing , looked like a splice to connect two lines with two fittings on each side.
Just wonder if I could use that and what type or kind of filter could I use. Or should I just stick with one from Fuel pump to carb and try to make it work?
