Adding a switch panel, need some help
protechk5
VA
Ok so Im adding a switch panel, 1 ingition switch and 8 switches, and start button. Heres one like mine
Heres my plan, I got the starter on start switch already. Im going to put the IP on the ignition switch(so that will be off and on for the engine) Then ill put the normal ignition stuff on the next switch. Ive got my glow plugs on one switch(and that light is red so it stands out). Ill probably add the radio on its own switch too.
But I need to know what 2 wires I need to take off the factory ignition switch and put on to my new one (just the wires that give power to the ignition when the factory switch in on the run position) Ive already got the starter wired up. Does anyone know which wires are which on the factory switch? Hope that makes sense.
Should be able to find it on a schematic.
Really though I have a question. Why put your IP on a switch?
i put mine on one. makes it pretty difficult to steal a truck that doesn't get fuel!
