Adding grease fittings
88k5blazin
clark new jersey
I just got the rock ram from supply warehouse that was the common ram I saw guys using for the hydro assist upgrade. It is the new style one with the pivot eye on the ends. Anyone add or think of adding grease fittings to the ends I was thinking about making greasable bolts to lube the center and then I was thinking about drilling a 1/16 hole from the outside eyelet down to the pivot ball so it greases inbetween. Any thoughts? It seemed pretty beefy but I don't want to compromise the strength by drilling if doing so will create a weak link
