Well my 52 inch springs are way too soft so i want to add a leaf or 2 and was wondering what leaves have you guys added or think i should add and where in the pack to put them?
Sure. I think for my fronts I ended up with six leafs, mixed and match from two sets of 52"s, until the two packs were reasonably level left-to-right, and I had the lift I wanted. The larger # of leafs might limit flex, but I seem to still have enough:
I just put 'em in size order, longest up top and shortest on the bottom
Pro comp, Skyjacker, Rancho, Superlift, all make Add A leaf kits. They come with everything you need. Cost is around $150 or so for front and rear. Will also lift your truck aprox 2"
Alright thanks looks like i will be looking for another set of 52's. I dont want to use an add a leaf because those r usually really thick and will really limit my flex
