Adjust High Idle?
thirdstreettito
Angier, NC
Well, I see on the end of the rod in the high ifle solenoid there is a slot for a flathead screwdriver. Im guessing its the adjustment screw. When I cold started my truck this morning(because cold start=high idle)I turned it right and it barley moved, so I turned it left and it moved and the idle went up maybe 50-100RPM. How far can I turn it? Also, how do I hookup a high idle switch? So I dont have to get a stick for the pedal. Thanks in advanced.
