I'm still in sticker shock. For two C-notes do those come with a reach-around?
I hear you. I'm fortunate enough to get to pull a lot of newer boats, and am often in charge of moving boats around at tournament lakes.
Hitch height requirements were pretty standard, until recently, when Mastercraft started using a new style jack that has an adjustable mount, but no one bothers to adjust at the factory.
Therefore, unless i disassemble and adjust other people's trailers, i can't get the new trailers to drop down low enough to land on the ball if it's set for my boat.
I raised it up for this reason, and now my trailer pulls with its nose in the air, and the prop guard an extra inch closer to the ground
With this requirement, an adjustable height one seems to be where it's at.
For the 91, I can always just carry 2 ball mounts, one up and one down. If i end up getting a newer rig, the one i'm looking at is lifted, and 2 large drop hitches at different heights put me close enough to an adjustable that it seems worth it.
That being said, I always use a 2" ball. Haven't had a need for a larger one yet, but if i get a tow rig with some actual power, maybe the opportunity will present itself.
Thanks for the feedback guys!
