Adjusting TPS for power and mixture?
mtrdrms
Torrington, CT
Can I richen my mixture by raising the voltage on my TPS? The suggested is .64v and someone here told me .54v but it seems to be down on power now and appears to be running lean with the .54 setting so I want to go back but will it hurt anything and does it actually richen the mixture? FI gurus UNITE!
no you cant.
the ecm just uses the min value to see that the throttle is closed. .54 or .64 wont matter.
ryan
No, changing the 5V reference voltage to the TPS will have no effect on fuel mixture.
The TPS simply measures throttle shaft position as the name implies............on the same note i am curious as to how you would actually change the reference voltage.
At idle speed the TPS output voltage should be below 1V and increase in a linear fashion to 5V as the throttle is opened to the WFO position.
Changing the fuel mixture is accomplished by changing the dwell and/or duration of the injectors duty cycle which has no connection with the TPS. :bow:
put tinme and $ into good quzlity fuel pump and regulator mods and real good large wires and real nice plugs and such
and k & n air filter too
and a real good ignition module
these will all help perfomance and efficiency/mileage and everything like that all at once
good luck
