So I have a 87 sub that I may swap a crew cab onto and don't mind stretching the wheel base a little to push the rear axle back a way from the cab since there is room between the axle and fuel tank. I would like to do this first before I swap a blazer tank in and trim the frame rails or just run the suburban tank.
Is their any advantage of reversed 56" suburban springs? or does this just benefit a blazer with stock 52" rear springs.
Wont this push the rear axle back 3-4"?
Any thoughts?
Any thoughts?
