adventure today
78Suburban
Georgia
I had a ball today.. it was raining and I took my burban out wheelin on the dirt roads.. it was so much fun...... once I completely bottomed out my front and rear axles, so me and my buddy were able to find some big rocks and put them under the back tires... and I finally got traction and got unstuck.. we went about 10 miles total and hit some decent mud holes..
but there were 2 little problems I would like yall to help me with..
1) the 203 kept popping out of low lock into low when I was spinning/stuck.
2) two times when I hit the throttle around a cure and for a 5 seconds after that, the truck sputtered really bad, and acted like it wanted to cut out...
any ideas on what's causing either one of these problems?
thanks..
Some 203s I have seen move around a lot more than you think they would my older blazer (73) has an extra mount and it helps alot also you can adjust the shifters mabey just a bit of playing with that would help we fixed one 203 by just dousing the shifter box in WD 40 a couple of times
Grim says you need a seat cover to keep her foot on the shifter :D
