Advice On Axle Spools
4wheelin4Jesus
north carolina
My buddy is telling me that i should use an axle spool. He said that they are strong, and i will not see much problems with steering, and handling on the road. Has anyone had any experience with them, good or bad?
I personally do not recommend spools in the rear axle if you plan on driving on the street. You will bark your tires on every turn and get really poor tire wear. I have a detroit in the rear and it will perform as well off road and will unlock around turns (just so long as you are not on the gas or brake). If you are installing on the front then it won't matter on the street with the hubs unlocked. Plan on having some turning upgrades to get it to work on tight trails. Unless you like getting out and unlocking one hub to make a tight turn.
I think the best offroad setup is locker rear/ selectible locker front.
I run spools front and rear. and yes it has it's little quirks but nothing that minding your driving manners won't fix. :D
I ran a spooled rearend on the street for 3 years. It is doable but the tire wear is insane. I recently switched to a Detroit locker in the rear axle and I was shocked at how much better it acts on the street then the spool did.
If you are building an offroad truck that sees more dirt then street then a spool is fine. But if you run the street alot you will get tired of the chirping around corners and the rapid tire wear issue.
Offroad you will not really notice a difference. A locker and a spool are going to provide the same amount of traction. A spooled front axle can be a PITA offroad as it will make it harder to steer the truck.
As far as steering with a spooled rear on the street your turning radius will increase a fair amount. A spool is not real user friendly on the street if you DD the truck. It can definitly be done though. Like I mentioned I did it for 3 years on the street.
The only bonus the the spool is that they are cheap, strong, and they have a very predictable road manner. The locker can be a little quirkie with the locking and unlocking especially in the ice, snow, and rain.
Harley
my rear axle is a 14bff. It is the 10.5" ring gear with 4.56 gears. It is technically a 3/4 ton rear axle but is the same strength as a 1 ton rear axle.
Harley
