After fire
Chevk587
Whiskey bent & Hell bound
California
Hey guys got a serious problem , so my 87 blazer 5.7L run great when cold once it get hot / ran for awhile and not engine temp wise just running for awhile starts to back fire misfire and die if I keep on the throttle . If I stay at like 1000-1500 rpm it's ok but push it any further then as stated above happens . Any ideas cold runs great no problem . I'm thinking clogged cat or a coil going bad any suggestions???
Coil and module are the easiest things to check. There is a trick to check the cat that I don't seem to hear about as much as I used to.
You pull the oxygen sensor and attach a pressure gauge to the port. A stopped up cat will show up as excess pressure.
Ahh good trick didn't think of that ! Gonna change the coil first cheapest and easiest !
I don't think I'd just be randomly changing parts, but that's me.
Plenty of HEI testing procedures to be found on the web, all you need is a multimeter.
I'm pretty familiar with testing procedures it's an intermittent problem thanks for your 2 cents ! Just looking for a place to start hard to fix something that's not always broken !
Have you pulled the plugs and check their condition to see how each cylinder is behaving?
No I haven't I will at pismo beach this weekend without my blaze :( gonn fix it ASAP. ! Pismo is sick!
