elks
Hey all,
I am in the middle of a rebuild on a 350 motor. Originally I was going to use the factory head until I found a small crack on a valve seat that would take a significant amount of machine work.
I am running a flat top piston, 30 over, upgraded intake, 650 cfm holley carb, and will get a decent power adding cam. I have access to 2 guys who are absolute engine nuts. One has built over 30 350 motors. Of course he is retired and can afford a $3000 set of heads. I am needing to stay around $750.00 to keep my budget.
where should I look? I know several places that are good for jeep heads, but I am looking at an entry level Aluminum head from a couple different places for the $700 range. There are several on ebay... Thanks a ton for the help. Just want to build my first engine right.
