Aftermarket disc brakes...not caddy calipers
jtrux
San Antonio, TX
I am going to be redoing the brakes on my V1500 soon and was wondering if anyone has installed Wilwood disc brakes or anything along those lines on their rig?
I don't want to get into a discussion about cost, but more about how they perform and what not.
Still running a 10 bolt or different?
You’ll probably find more folks have swapped to a later model factory disc (with ebrake) axle than Wilwood type stuff.
Then he would probably be looking at a gear change.
I have a "per-engineered" Baer kit on a 2wd Tahoe (not an apples to apples comparison). They look trick and work awesome eventually.
The front hubs are quality pcs but widen the track 1/2" (which no-one @ Baer was aware of an not as much of an issue on a lifted 4x4).
All the brackets for the calipers required reworking and are a bit flimsy.
Parking break required even more reworking which is unacceptable for a kit.
Looking at putting better brakes on my K3500 w/SAS swap and will most likely use the bigger dodge brakes on the D60 and the rear disks off a GMT800. Cost isn't the major reason, pure aggravation of redoing a per-engineered kit is!!!
Another plus is local/trail availability of OEM parts. (that being said, I just ordered a front/rear brake kit from Wilwood for an AMX because factory parts are obsolete...fully expect to have to modify something though) :dunno:
Somebody must have grafted on GMT800 rear discs with the drum-in-hat parking brake by now. Must be a million of those 10-bolts in the junkyards. Might be able to rework them to mount on the square-body 10-bolt backing plate mount.
Yeah, just have to cut off the trailing arm mounts, coil spring buckets, etc and put some leaf spring pads on. Re-gearing is almost certainly required. Might be some 3.73 out there, but a lot of 3.42.
