aftermarket gauges
original balzer
roosevelt utah
Do any of the aftermarket gauge lines have other gauges that match such as air pressure, egt, boost, and a clock? I have been looking but have come up short. I can find them but I would rather EVERY gauge matched. I dont realy care what style they are as long as the are dial sweep and easy to read.
Matching gauges
Autometer and Sun Pro both sell "kits" that include matching speedo, oil pressure, gas, water temp and amp gauges. I believe both companies also sell other gauges that match the ones in the kits. I believe you can get matching Stewart Warner gauges. They're on their website.
Well after gong through autometers entire line up I finaly found the ones I want and they all match. They are the Z series, they even have a diesel tach in that line, even if it is a pedistal mount and only 2 5/8" it is desinged for the alternator input. If you go to their web site you may notice the Z series is dead last. I went through ALL the others and didnt find all the gauges I wanted that matched until the Z series. While they are not the fanciest they would do the job in the crew cab it aint gunna be pretty anyway.
Once again the gauges I wanted are,
speedo-3 3/8 0-80mph
tach-diesel variation in 2 5/8" 0-5000rpm
(all below are 2 1/16)
water temp
oil pressure
fuel level
volts
EGT/pyrometer
boost
air pressure
and a clock
