I have put a hault on my 87 blazer build but looking forward on starting up again since it's more than half way done. I'm looking into getting the DIY4X dash and will need some help on which gauges to get, mechanical or electric. My engine is a 383 stroker with a holley so no efi. Tranny is a R700 so there is a mechanical cable for the speedometer, thinking of running a tach, water temp, oil temp and oil pressure, trans temp( should a run a switch for different temp reading? At cooler and tranny?) Clock, fuel. I'm tired of dealing with the old gauges and once it's up and running just want to do maintenance. Please give your thoughts and advice on brand and line of gauges. Thank you in advance.
