So, I finally got my parts to put a 91 quad lamp setup on my 84 K2500. The rad support I got has some rust where the center vertical and horizontal piece's meet. Most supports I looked at from the North East were far worsee then this one.
Anyways my question is about the aftermarket ones. Are they as bad as the local opinion make them out to be? I'm told not only are the new ones ill fitting, they are flimsy compared to the OEM.
So before I start welding in a patch panel or 2 is it worth considering the aftermarket one?
Thanks!
Thanks!
