jones
Is there a reason the gauge will not drop below 190*
even after cooling down,it's stuck at 190*
When it gets up to operating temp.,it reads 230*
It freaked me out when I saw that before I realized the gauge was stuck.Is there a way to reset it or something?
Thanks!
Thanks!
) and when I started the truck for the first time the one that is getting the charge first was showing only 11 volts. When the other gauge got the charge it showed the 14 volts as it should.
. I dont understand where the problem could be but hoping the warranty will cover it.
