I am installing new U-joints in my rear driveshaft. Popped the old joint out no problem. Now installing the new one I installed it and put in one snap ring. Flipped it over to put in the other one and there is not enough room. If the snap ring was half the thickness it would fit thats how close it is. I un did the other side and tried it the opposite way..no joy. Its like less than 1/64 too tight.
The old one came out easy. Snap rings popped right out and used a C-clamp to push the old joint out..easy! Why won't the new one fit?
Both 1350 joints.
Any tips tricks?
Both 1350 joints.
Any tips tricks?
