Was looking online and see some air springs or bags are available for 73-87 GM 4x4 trucks now (not cheap however !)..was wondering if anyone has tried them,to boost up original springs when a plow or heavy winch was added up front..
My truck rides like a buckboard with its original 2 leaf sagged out front springs--I have maybe 1/2" clearance between the rubber bump stops with the plow off,and it often bottoms out on them,I have had to replace the snubbers that are located in the center near the u-bolt pads,it tore the rubbers right off last winter when I left the plow on most of the time...
I've thought about adapting a pair of those 1500 lb. coil type overload springs to bolt up where the rubber bump stops go in the center,rather than replace the oem leafs or add any leafs--too much work for me,the truck isn't really worth it ...thought about getting a pair of those shocks with the overload springs too,but those now cost nearly as much as springs would..
