air, co2, nitrogen poll
which would you rather run for airing tire's and arb????
  • air compressor with back up tank
    Votes: 19 57.6%
  • air tank
    Votes: 0 0.0%
  • co2 tank
    Votes: 8 24.2%
  • nitrogen
    Votes: 6 18.2%
  • Total voters
    33
  • Poll closed .
vtblazer said:
What about the co/2 coming out @ 100 degrees below zero? :eek1:
Any issues with that?
Never had any issues with the impact or airing tires. Wearing gloves would be a good safety precaution.
Thanks guys I now know I will be using a co2 tank, I can get a 10 lb tank filled for $$93.00 plus tax here, and was told they fill it for $13.00 a shot, I like it for its portableness. I found a web site that has the mechanical switch for the arb so I will be using it and mounting the tank in the bed, I plan on running hard line as far as possible and then some spiral hose for the locker. I all so plan on running a Y so i can fill tires or run air tools:laugh:
Would love to see more pics of the tank locations!!!!!
I have mine mounted at about 45 deg on the front of the pass side wheel well in hte bed. I know i have pics of it somewhere around here.
I came across the first problem so far just two nights ago. Cold weather plus cold CO2 = Freezing tools and regulator. Might not be a problem for guys running a constant pressure regulator though.
