lectric80
3/4 ton status
My dad picked up this Campbell Hausfeld compressor for my little brother, but because the head is leaking he was a little iffy about it. I went ahead and took it and want to get it set up in my garage, hopefully I can use it to help with body work on the Camaro and possibly eventually paint.
Anyway, a little detail, it is a 60 gallon, twin cylinder 6 HP unit. It is pretty obvious, at least up close, that is was blowing oil out of the back cylinder at the upper gasket. The problem I have is I need to identify the pump head for certain, the PO stated they had replaced the pump head at some point, so I make sure I get the right gasket set. Is there supposed to be any markings on the head? The tank appears to be from 97 based on info on the tag, but I don't see any markings on the head itself to identify it. He picked it up for $250, which is what I'm paying him, so if I had to go worst case scenario I could always replace the whole head and still be within the value of the unit I think.
Here are a few pics for reference:
Overall:
Head close up(side):
Front view close:
ID tag:
Motor ID tag:
So, any tips on identifying the pump head? Any tips on mounting it, as I have never actually had a big compressor.
Working on the garage this weekend to hopefully get it cleaned up and figure out where I want to place the compressor. Also need to get with a buddy of mine to run the power out from my secondary range circuit as we don't use it and I want the 220 in the garage for this and a welder or two.
Overall:
Front view close:
ID tag:
Motor ID tag:
