I’ve had a Campbell Hausfield 21 gal 110 powered 200psi air compressor I bought at lowes about 4-5 years ago.
For the last year or so it had been acting up and not always turning on. Fiddling with the switch would eventually get it to work.
A couple of weeks ago it stopped all together. I purchased a new regulator assembly (only way to get a new switch) and installed it yesterday. Still not correct.
Occasionally it will run when the switch is turned and it never gets to the full 200 psi. At first it was 40-50 but then I saw 90 and 150.
Any thoughts on what’s going on? Has power coming in and when the switch is engaged.
