air compressor question
1983Blazerkid
brownsburg, in
ive got an air compressor and im getting quite abit of oil through the lines got a water/oil seperater on the line but seems like there is still quite abit through it. any input would help. i was going to buy like a new ring kit for it and see if it works just wanted to see what you guys thought first thanks cody
cody, is it fairly new? our compressors do that if you dont retorque the head after the first 15 hours then 50 hours...
that will affect it, does your seperator have a drain valve? if so, have you drained it or the tank lately?
when I got my 80 gallon compressor I filled it up to 120psi then released the valve on the bottom of the tank and I got a TON of gunk to come out...so I was just thinking that if your line is towards the bottom of the tank and you haven't drained it in a while it could cause that.
