OK, just made a quick run out to your place and back from Fl. and peeked under the hood. Definitely the compressor......
Seriously, the clutch freewheels on the compressor, driven at all times by the belt. If the clutch fails, it will either be locked up all the time, or be wobbling and making noise all the time.
While the clutch turns all the time, the compressor only turns when the clutch engages.
Since there is no problem while the clutch is not engaged, its fine. When you engage it, it locks the belt to the compressor.
At which point it stalls the engine.
This means that the compressor is locked up.
Like I mentioned, the r4 is the only compressor I have ever run into that can fail "clean".
Most compressors come apart over a period of time and spew tiny shavings of steel and aluminum all through the system.
An R4 can do that to, but if the piston rod pops out of the scotch block, it seizes on the next revolution, and often there is no metal escaping from the compressor.
You still need to flush the system, change the drier, and the orifice tube.
If you find lots of black crud in the orifice tube, your system has the "black death".
There are several explanations for this.
Some say its a breakdown of the oil that leaches solder out of the coils, others say it comes out of the drier.
I suspect that there may be more than one cause.
If you find that, you need to disconnect all lines, replace the condensor, which you need to do anyway if you are going to 134a, flush out everything you can, replace the compressor, drier, orifice tube, new O rings, new oil, and keep your fingers crossed that you do not have to replace the evaporator.
That black crud just will not flush out, but it will break loose over time and clog everything back up.
Hopefully yours is clean, so normal stuff is all you need to do.
BTW, here is a picture of a R4 compressor.
