When I bought my 89 Blazer the AC didn't work. I mean, it seemed to turn on correctly but no cold air. A few years later, today, I decided to check the system out.
Everything on the outside looks in good shape, hoses, connections, electrical, etc. One hose connection was loose but barely. I imagine that is why the system was not getting cold. It was empty via the loose connection. It was the connection right before going into the top of the evaporator.
I turned the AC to max, the fan to hi, and temp to cold. I could hear the vaccum working and flaps adjusting. A lot of air was coming out of the vents but it was hot air of course. I jumped the compressor via the low side switch and the clutch kicked in so the compressor clutch seems to be working. No wierd noises when I jumped the compressor. A bit of rust dust but that was due to inactivity for who know how many years.
Since it was already empty I bought the ID Q Recharge and Retrofit Kit. It has 134a, Oil, and sealant. It also has the adpaters for using R134 fixtures. Probably not the best route to take but I took it. My system say it should be charged with 3.25 lbs of R12. So I used the 85% rule I used in the instructions of the kit (3.25 x .85 = 2.76 lbs of 134a needed to replace the R12). That comes to about 44oz of R134a needed to get the system working. I installed the R134 fittings on the low and high schrader valves, then set the selector switch on the retrofit kit to ambient outside temps, then started filling the system.
I never did get any pressure to register on the retrofit kit regulator but I know R134 was going into the system. I didn't try to get reading when I jumped the compressor clutch as it was just a short quick test. I used approximately 44oz of 134a and the compressor clutch never kicked in or even seemed like it tried. I looked the system over and didn't see any leak areas so I know the system has to have SOME pressure in it. I just don't know why it didnt register on the kit's fill guage.
Now I am stuck. Not sure what to do. Suggestions please?
