buff_dog70
I am trying to re install A/C in my 82 Jimmy with diesel engine. As I was going through all the fittings (putting new o-rings) before I evacuated and charged, I noticed that the the hose fittings from the manifold was using a tapered fitting instead of the standard a/c o-ring fitting. It does not look OEM. The entrance to the condensor is on the passenger side, not the drivers side. This non-standard fitting is on a small adapter that allows one to mate the male thread (non o-ring side) coming from the compressor (it also is fixed, does not rotate). To the male thread coming off the entrance to the condensor (non o-ring side, and fixed does not rotate. This small adapter piece has an o-ring on one side and the tapered fitting on the other, with the proper thread rotating nuts on both sides. But I don't believe the tapered fitting will seal properly against the standard fitting coming from the a/c manifold. The a/c did work when I purchased the vehicle. But I wonder if I was slow leaking the entire time. I was going to try and build the proper adapter with o-rings on both sides. Also how many lbs of r-134 should I put in? How much ester oil? The system was open for a long time, I also replaced the accumulator.
