Air control valve
cybrfire
1 ton status
Iowa
Anybody have a good source for ride height control valves?
Need a pair for the crew cab for both sides in the rear to prevent sway and control height.
Not much online that I can find for price comparison. Thanks.
If you don't mind big rig part, you can readily find them through truck parts suppliers. Midland is the brand name that comes to mind. I can't remember the other one I've used at the moment.:doah: They are ride height valves (attach to frame) with an arm that attaches to a pushrod fom the axle.
Well that turned up some comparision info. Thanks!
I was assuming you were looking for automatic levellers as opposed to manual controls. I saw some manual valves with a dual guage on a stepvan today. They were by Firestone, Ride-Rite series IIRC.
Automatics for sure.
Manuals, i'd assume are for controlling ride height only?
They are used on an overload type airbag setup and used a duplex gauge to show the pressure in each bag. Just throwing out options. Also, I think Haldex is the other company I was trying to think of that makes an air levelling valve (auto type).:D
Well, I got a set ordered up. Just a matter of time now.
