blaznaro
Registered Member
Wondering if anyone knows which Air filter base is best for use with the salad bowl , ie..."power charger" for tbi from Hypertech... I have gotten my throttle body mounted with tbi spacer and all mods from morse machine except the adjustable pressure regulator, which will be done eventually. Just need to get the correct base so i dont have any clearance issues with closing the hood and also to make sure that the base will not interfere with the throttle and tv cable alignment etc.....Filter size and lid recommendations also needed. Thought about the spectre unit with the filter in the lid but not sure if its worth the extra money..... any advice will be appreciated Thanks !!!!!
what size base plate won't cause any problem ????
