I think around 1975 is when they added the APT screw..when emissions became a big deal,and they started using catalitic converters,EGR valves,and air pumps on most cars..
I had a '75 K5 2wd Blazer with a 250 six and a one barrel carb,that engine had a bad lean surge when cruising around 30-35 mph..it also spark knocked like crazy with the timing set to specs,I had to retard it by 4 degrees just to get it to a minimum and that only aggravated the lean surging condition..
I tried rebuilding the carb,plugged off the EGR valve,nothing seemed to help--until I read about that APT screw hidden under a lead plug near the bottom of the bowl..
The carb kit instructions said in BOLD print "Do NOT attempt to remove or adjust this screw--it is factory adjusted for lowest emissions and attempting to remove or change its setting will result in higher emissions,and possible damage to the carb casting"..
That was all I needed to read--I immediately drilled the plug out...
and saw the screw had a slotted head--I unscrewed it a bit at a time,until several test rides showed after 1-1/2 turns out,the engine ran smooth and no more surging & bucking..being a manual transmission that was very annoying..
Only trouble I had after that was trying to seal up the port where that plug was originally..I tried epoxy paste,a tiny freeze plug,but it always weeped,and the screw pointed down at the intake & exhaust,so a fire hazard was a possibility..I ended up putting several coats of Indian Head Gasket Shellac over the area and it finally sealed up..
