Hmm, the exact problem that I have, it's illegal to remove and will fail visual inspection. Very frustrating, as the air pump has no filtration system on it and thus would be sucking muddy water and shooting it into my exhaust also, mine appears to have a tube that runs up to my air cleaner assembly too so, it'd be shooting muddy water up there to, real smart design!
Anyways, I tried to do what is (evironmentally) right, I talked with the guy in charge of inspections around here (NCDMV for my county) and asked if I could put in a Vortec 6000 engine swap, lower emissions, better fuel economy, etc (I would be retaining all the emissions equipment that came on vehicles with the Vortec 6000). This would be a great swap in terms of impact on the environment for the reasons I just stated! But, he said, "if it doesn't have a smog pump, it will fail". I responded saying that the smog pump is an outdated emissions device and the Vortec engine would put out less emissions and that I would even be willing to have my truck held to an OBD II inspection standard, knowing that this is a lower polluting set up. He said, "no, we wouldn't be able to do that, it would just be automaticly failed for not having a smog pump." What a bunch of morons!
So, although I do not want to, it sticks me thinking about tearing off the air pump system and become another polluter (maybe even not register the truck and have it be offroad only) so that I can use the truck for what purposes I bought it for, just because the DMV (inspections division) is filled with idiots!!!
I don't know if your DMV is this blatantly stupid! Maybe in your state, you can swap in a newer motor that doesn't have a smog (air) pump and have the best of both worlds, lower emissions and no ugly, mud sucking , piece of $#!+ smog pump!
MAYBE IF THE GOVERNMENT WOULD GET A CLUE, (IE IF YOU WANT TO SWAP IN A BETTER EMISSIONS MOTOR YOU SHOULD BE ABLE TO) WE'D ALL BE HAPPIER!
Hippies, fourwheelers, everybody!
