air tank
Westside K5
Registered Member
Muskegon, MI
located in North Muskegon
$65 obo
The tank is 31" tall, from bottom to the top of the fitting and 7.5" in diameter, since I don't know the thickness of the tank walls, I can assume the volume is between 3 & 4 gallons.
It was originally made for planes & boats (this was from a plane) but can no longer be used for that purpose, it is out of date.
It shouldn't be used for it's rated pressure anymore, which is 1,850psi, but can easily handle the normal pressures a compressor can put out.
It weights 13#'s.
The fitting on top is a 3/4" NPT.
I'll ship if you want, you pay the shipping.
Thanks, Jeff
