air up/down systems
A set of staun deflators is just as easy for airing down, and if you have a decent on board compressor it'll take the same amount of time with a single hose and doing each tire individually. The compressor can only make so much air, so with 4 chucks hooked up each tire will inflate at 25% the speed of doing them individually.
Plus, the Staun deflators fit in your pocket and don't need monitoring once they're set.
Rene
