"Airflow" bellhousing picture
mountainexplorer
Spokane, Wa./Ione, Wa
Anyone have any theories on how this could have happened? Supposedly there was a fire involved. That is all I know. The rest of it is still attached to the SM465 and the clutch disc and pressure plate are still on the input shaft.
Where's the flywheel?Did the flywheel break cutting the bellhousing and into the fuel line causing the fire?
I got the truck as it sits with no motor, and no flywheel. This is all I found in the back of the truck, what's left of the rest of it is still on the transmission. The guy I got it from was told by the guy that he got it from that the guy that he got it from said there was an "engine fire". It didn't do much fire damage at all in the engine bay. It looks like it was all right on/over or within the bellhousing area.
It's a TBI 454 '91 GMC Crew Cab.
TBI engines have the fuel lines running up the back of the bellhousing, and a fire will melt aluminum...
Well congrats on your newest of new vehicles. Pretty weird bellhousing though. Makes that inspection cover look strong. :haha:
Can't see the pic clearly enough but maybe someone used a plasma cutter to QUICKLY remove the engine and just cut through the bellhousing. :dunno:
