jonathon
I'm sort of lost when it comes to adjusting my drag link and doing the alignment(just need to set toe). My haynes book is useless..
I bought a new drag link because the old one had bad ends, figured the extra $10 for a new adjusting sleeve was okay and would make life easier. I am just not sure how to set it.. and the old drag link was way off(at least I assume it was, the wheel was half a turn out and the box was not centered).
I'm almost wondering if I should get the toe and alignment set with the wheels facing straight and the box centered and then install the drag link.
Any input? I'm lost..
I think my problem is I'm trying to install and adjust it with the tires in the air versus just straight and on the ground.. before I messed with this, the drivers side tire was straight and the passenger one pointed out a bit(just like my other burb when I took it to be aligned after hitting a curb). Nothing is broke that I can see.
This is after new wheel bearings, ball joints, drag link ends, and aligned. I think the toe might not be quite right.. would that cause it to randomly head one way or the other? It's a gentle sway/turn that can be corrected by slightly moving the wheel.. but I know it shouldn't be doing that.
